跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.Also known as the Samsung SM-G998U1
S21 ultra not recognizing usb device's
Why does my galaxy s21 ultra not recognize usb device's for file transfer or wired ear phones
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hello,
Try taking a look at the settings. I believe there is a security setting for external devices. Try looking inside the privacy and security settings. If there are no settings causing this issue, there might be a issue with the USB C port. I hope this helps!
这个答案有帮助吗?
得分 1
3条评论:
If I plug my tablet into my phone using the factory type c to c cable it allows me to charge my tablet but no file transfer
完成的
You need to activate developer options. You can do so by going to your settings-about phone-software information.Click on build number 7 times. This activates developer options. Go back to settings and scroll down till you see developer options then click on it. Scroll down till you see options for debugging. Click USB debugging to turn it on. This should allow you to transfer using your C to C cable.
完成的
@tia rose , thank you sooo much! It read as soon as i followed those steps. Appreciate u mann
完成的
添加一条评论
添加你的答案
timothy walter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 77
总计 9,433
