跳转到主内容
A smartphone by Samsung running Android, identifiable by the model number GT-S5570, released in 2011.
19 个问题 查看全部
Why Samsung GT-S5570 Mini not turning on after pressing the ON switch?
I have a Samsung GT-S5570 Mini which was bought in 2014. I was able to use it until February 2018 when it no longer turns on due to problems with its ON switch. Sometimes the ON switch works but most of the time the ON switch won't work.
Now come February 2023. I turned on the Samsung Galaxy GT-S5570 Mini and alas! It turned on! It seemed not to have problems for few days but it seems the problem with its ON switch starts to creep up. I even need to strongly press the ON switch to turn on the phone.
Few weeks ago, my Samsung GT-S5570 Mini phone wouldn't even turn on even if I recharged her batteries.
I bought the Samsung GT-S5570 Mini to the repair shops and they all said that there is a problem with its board, but they couldn't pinpoint where is the problem in the board.
Why is Samsung GT-S5570 Mini not turning on after pressing the ON switch?
Thank you for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Loose button, faulty board, a lot of different factors go into trying to pinpoint the problem. If it is a board problem swapping the board may be a solution but it could also be an issue with the physical button (that you press) not actually touching the button on the board. I would have to see inside to make a more informed answer.
这个答案有帮助吗?
得分 1
1条评论:
Turns out a loose button is the culprit. The board was fine....
完成的
添加一条评论
Update: I was able to turn the said phone again. The board of my Samsung GT - S5570 Mini unit doesn't really have any problems. The problem lies in the power button of my Samsung GT - S5570 Mini unit and I can't directly push the button in order to turn it on. I have to angle a stick to the power button and press it slightly sideways just to turn on the phone.
Probably there is a loose contact inside the power button of my phone and needs to be replaced.
The next challenge is how am I gonna find such power button in the Samsung GT - S5570 Mini unit in the Philippines.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fitzmerl duron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 142
