Camera won’t let me format my SD card & keeps prompting me to format.
I bought a new Sandisk 64 GB Micro SD card for my camera and the camera outright refuses to format it. I will click yes and it still won’t format. I’ve tried another Micro SD card and it works just fine. Anyone else have the same problem?
8条评论
Hi @bruhflag,
Have you tried formatting the SD Card in a computer?
It may be a faulty card.
由 jayeff 完成的
Heya @jayeff !
I’ve tried that just now, and it isn’t working. My card reads fine on my computer, just not the camera.
由 BruhFlag 完成的
@bruhflag
By "reads fine" did you try "writing" to the card in the computer?
Formatting involves writing to the card and then reading the result.
Try formatting it in a computer and then copying some files to it.
If no good try cleaning the gold contacts on the card with a pencil eraser
由 jayeff 完成的
@jayeff I just loaded some JPG files on it and it reads and writes perfectly well.
I’ve just tried cleaning the contacts with a pencil eraser, no luck either.
由 BruhFlag 完成的
@bruhflag
Don't know.
If it is only a problem with that one card and not other cards as well then there's a compatibility problem between the camera and that one card.
Were the other cards also 64GB?
The manual says that it can handle up to 128GB cards but maybe it can't for some reason especially if the other cards weren't 64GB or higher either so that you know it can
由 jayeff 完成的
显示更多的3条评论
