跳转到主内容
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 个问题 查看全部
Why are my menu buttons (home, search, back buttons) not working?
The menu buttons on my Samsung Galaxy Tab 7.0 aren't working. Why is this happening, and how can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 216
68条评论
My munu buttons back back button and remaining two buttons are not working please help me what is problem
完成的
Thank my home button and my other to button is working now because I took it out off the case thank you for a good comment on the phone and tablet
完成的
Back key and recent key are not functioning
完成的
完成的
Is there any app which can show the botton on the screen
完成的
显示更多的63条评论
添加一条评论
22个答案
已选择的解决方案
I had this problem. I realized that it wasn't actually a problem with the tablet. The case it was in was putting too much stress on the tablet, and this inhibited the home and other keys. Once I took it out of the case, it was fine.
这个答案有帮助吗?
得分 57
57条评论:
I have the same problem, does this mean that we can't put the tablet in a case ?
完成的
You're right! I tried to put it off then it works! Put it on again, the home-search-back button not working again!
完成的
I just read this post because I was experiencing the same issue. I removed the case and boom all is working again! THANK YOU!
完成的
Same here...took it out of the case and now it works just fine
完成的
It's not "stress on the tablet"- it's the magnets in the folio that are affecting my device.
完成的
显示更多的52条评论
添加一条评论
Dial on keypad *#2663#
and press on TSP FW Update and it will resolve back button problem..I searched lots of tips to solve it..i've done lots of solution they told..but this thing rescue me..Cheers
这个答案有帮助吗?
得分 39
48条评论:
Thanks joel, it did work for me.
完成的
this is the only solution on the page that worked. thanks
完成的
Joel I dont know who you are or where you are from, but my simple words to you are THANK YOU SO SO SO SO SO SO SO SO MUCH you are a life saver. Your solution worked like a charm :)
完成的
I dialed *#2663# in my lenovo k3 note for solution back key.it show invalid mmi code.what is the meaning of it? And please tell me how back key and middle key of lenovo k3 note will work?I m so worry about this please....
完成的
I wish this helped. I entered the code but it gives me an error message :(
完成的
显示更多的43条评论
添加一条评论
Hi Guyz,
Its very simple way to get rid of this problem.You just download an app from play store named as
"Back Button (No root)" install it and enjoy the functionality of all buttons like home,back etc.Its actually helpful if your androids menu main menu buttons are not working.
or you can search via browser here it is :-
https://play.google.com/store/apps/detai...
Thanks,
这个答案有帮助吗?
得分 14
16条评论:
Its really works plz try this.
完成的
Its really very good app. I have problem in my Lenovo K3 note yesterday onwards. when i approached service center they have informed screen and touch combo has to be changed for that he is charging 2000Rs. By this Back button app my work is so simple. Thanks a lot.. I had been using this mobile from past 21 months. But no issue. Only yesterday i face this back button not working. I though i ll go and buy new mobile MI-4 instead of reapair. but this app saved my money. Thank you guys..
完成的
Worked like a dream. I tried factory reset. Reset to default settings. and *#2663# on the keypad. The app works for me. Thanks @rajsingh
完成的
super bro really working
完成的
Thanks! It's helps a lot.
完成的
显示更多的11条评论
添加一条评论
i had same problem once i take it out from case i start working perfectly
这个答案有帮助吗?
得分 11
3条评论:
what is meant by case?
完成的
I don't understand what do you mean by case and how does work
完成的
I try this but updation is failed what can I do now ??
完成的
添加一条评论
HEY guys
I have lenovo a 6000 and I got the same damm problem with home key,menu key, back key
so I go in care centre that say that my lenovo's touch pad is gone and its charges are 2800-3000rs
but I got the temparory solution
download application like EASY TOUCH, SIMPLE SETTING,HOME LOUNCHER or louncher with home key,back key,menu key
but the best is easy touch application
but remember its temparory solutions
hope it will help u
THANK U
这个答案有帮助吗?
得分 4
2条评论:
but my back key is not gone.
完成的
Hi! My tablet is also lenovo but my problem is one side only working if u move it horizontally( turn it on right side) if I swiped down(ont the top)it won't show but if I swipe it up wards(down side) It shows how? To solve? Pls help!
完成的
添加一条评论
Try restarting your Device. I think it will work coz it worked out for me.
Good luck!!! ♡♡♡
这个答案有帮助吗?
得分 2
4条评论:
It must be the case coz I only experinced this since yesterday after buying new case
完成的
Restarting the deice helps but the problem repeats soon again
完成的
It doesn't worked on me...
完成的
I have many time restart my lenovo k3 note for working of back key and middle still it is not working.what I will do? please tell me Joel....
完成的
添加一条评论
I've also had this problem intermittently - have taken it out of its Bluetooth keyboard case (after a full factory reset seemed to have no effect at all) and it seems to be working... will see if it reoccurs! Thanks - I was nearly going to send it back to Samsung to try and get it fixed!
这个答案有帮助吗?
得分 2
添加一条评论
I had this happen to, I flashed the rom 4 times and even tried a 5.1.1 rom and still no back button.
I reflashed my rom back to 4.2.2 and all is good.
I haven't seen any fixes yet but personally, I hate lolipop anyway.
这个答案有帮助吗?
得分 2
1条评论:
Also had this problem and like a previous comment said, it was the magnet on my case that made it stop working. I folded the magnetic flap so that it would be easier to hold the tablet. Once I unfolded it and just let it hang there, the buttons started working again.
完成的
添加一条评论
I restarted the tablet and now it works! I hope this wont happen again. All you have to do is click the off button and turn it back on. NOTE: you do NOT have to turn your tablet ALL the way off! Just off & on. Ex: If the
If you cannot exit stuff, try the home button, then turn the device of and click the game and then turn it off. Hope I helped! :)
这个答案有帮助吗?
得分 1
添加一条评论
You can try using the back button app from play store. It works like charm
这个答案有帮助吗?
得分 1
1条评论:
thank you, thank you!!!!!
完成的
添加一条评论
I had the same problem I heard it had something to do with the lollipop upgrade, no its not, all you have to do is ROOT your device and hey presto its working again it did it for me!.
这个答案有帮助吗?
得分 1
1条评论:
How do i do that Peter?
完成的
添加一条评论
I had seen this problem in my new Lenovo k3 note today.I remove both covers for 1 minutes and then put back.
Now It got worked
这个答案有帮助吗?
得分 0
2条评论:
My recent apps button is not workin .. i already tried restore factory settings,restarting and nothing actually worked.. somebody please help me..
完成的
I have also same problem please help me...
完成的
添加一条评论
I had the same problem with my galaxy after I replaced the screen, was really annoying, tried a few things first like factory reset updates install uninstall, nothing worked so I replaced the usb docking port circuit board whatever you call with the help of YouTube and it has worked fine ever since, the component was only 8 quid! Buzzing!
这个答案有帮助吗?
得分 0
1条评论:
Yah thanks for your suggestions. It really works. My kids have wrongly put the case upside down . After putting in right position all keys are working. Thanks
完成的
添加一条评论
Your battery is saving power,so get in there and turn off the restrictions in the Power Saving mode. I was worried too,I trust that you would figured it out.
Update (06/04/2016)
Your phone when to Power Saving mode, and that will restrict your lights, apps, etc. Go to your Power saving menu and toggle it off
这个答案有帮助吗?
得分 0
1条评论:
Did that still not functioning
完成的
添加一条评论
Hope this article will help you out as the same issue was faced with me earlier...
http://infomash.net/home-button-not-work...
这个答案有帮助吗?
得分 0
添加一条评论
Install the touch keys app, if other part of the touch screen is working fine.
这个答案有帮助吗?
得分 0
添加一条评论
In my K4, I turned off CBAC in Power Manager and the soft keys are functional again..
But yes the picture quaility/display changed a little.. but am happy that the keys are operational..
这个答案有帮助吗?
得分 0
1条评论:
What! Battery saver making buttons disappear! BULLSHIT! Why talk when you just don't know the answer!
完成的
添加一条评论
Hello!
Check this video and really worked to fix problem with no working buttons bottom navigation bar...
Worked for huawei every models, and other android phones!
Hope to help you!...
https://www.youtube.com/watch?v=MKGrqV8z...
这个答案有帮助吗?
得分 0
1条评论:
It seems funny but it really works. Just tried and dropped my phone (on the couch) and everything is back
完成的
添加一条评论
There might be something
这个答案有帮助吗?
得分 0
添加一条评论
I did not solve the problem i have a galaxy tab a6 with no case if I put a coin on it everytime and wait 1 minute then the buttons work but it damages my coins.
这个答案有帮助吗?
得分 0
添加一条评论
Turn off the Power Saving mode.
Go to Battery and device care>Battery>Power saving mode
Then turn off the limit apps and home screen using toggle button.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
A new [Charger port flex cable]_that's it..
Its for hardware menu home back button and cherger and sim and speaker functionality
Disconnect the existing one
now turn on the phone just to see
If safe mode issue resolves if so
Buy a new one and replace it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
enshad74 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 104
总计 906,151
