power comes on click click then No picture?
Why does the power come on, then click click and the green light goes off and then no power?
This unit is equipped with a power failure detector function and will turn your unit of to protect from further damage. This model apparently has some trouble with bad capacitors on the power board. Check for bulging, leaking capacitors. You should also check this question for more info on this issue. Hope this helps to get you started. Good Luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,216
