跳转到主内容
The Honda CR-V is a compact crossover manufactured by Honda since 1995. Since It uses the Honda Civic platform in an SUV body it was called "CR-V" which stands for Comfortable Runabout Vehicle.
rear window washer nozzel broke how do you replace it
how do you replace a rear window washer nozzel on a 2007 honda crv
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @bobheller
Here are the relevant sections from the 2007 Honda CR-V service repair manual that shows what to do.
Go to p.22-225 of the body electrical (section #22) of the manual to view how to remove/replace the washer nozzle, after you have gained access to it as referred to in body (section #20) p.20-83.
Note: When you click on the links, once the documents have loaded (allow a bit of time to fully load), the page number is shown on the bottom right corner of each page. The page numbering shown in the document header bar is slightly out by about 4 numbers
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bob Heller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 44
总计 875
