跳转到主内容
第三代 Surface Pro 平板,发布于2014年6月20日。
Won't turn on - how can I get data?
Hello. Yesterday my surface pro 3 stopped wouldn't turning on. In case it was the battery/power, I tried a couple of different chargers - but both show the pro is charging, and still the screen doesn't turn on. I tried the hard reset by pressing and holding the power button - after about 20 seconds the charger light blinks momentarily before going back to being solid, as if to show the pro is restarting, but still no turning on.
I recently bought a new computer as the pro was getting old, and my concern is not the device, but the data. I last backed up the pro about a month ago. There is data on there I need access to. Is there a way of getting it?
Thank you very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @emmie3298
Here's one way which is not that easy but it's doable. Depends how much possible damage to the laptop you're prepared to accept.
Here's the ifixit Microsoft Surface Pro 3 SSD固态硬盘的更换 guide that will help.
Once you have gained access to the SSD (that's the hard part) and removed it, you should be able to then insert it into a PC that has a spare M.2 port so that essentially it becomes a storage drive in that PC and retrieve the data that way from the SSD.
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much!
完成的
添加一条评论
添加你的答案
Emmie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 388
