跳转到主内容
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 个问题 查看全部
My truck has power but it won't crank/start
I was checking my wiring inside the my cab to adjust my alarm sensitivity but around the time I did that I tired turning on my truck. I didn't crank and when leaving it in ignition on it still had power. Most likely a loose wire was moved or something disconnected, im not that sure.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is also possible that you ran your battery real low and it has enough power to run accessories but not enough to power the run the starter motor. Try either jump starting it or just charge the battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony Esparza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 100
