跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
164 个问题 查看全部
Screen very dark after replacement?
So I've replaced my screen with a new one, brought over the earpiece and now the screen is very dark. Face ID works fine and all. I've read that the ambient light sensor if damaged, will result in having the lowest possible brightness.
However, I moved back the earpiece to the original screen and brightness just worked as it should. Then I put it back on the new screen and it doesn't work. Of course, for sanity check, I moved it back onto the original screen and it all just works.
Is it possible that the new screen needs to be reprogrammed first for the brightness to work? What a goofy issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Remy,
I haven't run into a situation where the screen programming caused any kind of issue like you're describing. However, around here we've seen several cases where new screens came with protective layers of plastic down inside unlikely locations. Mostly it happens with the cameras, but I don't see any reason why the opening for the ambient light sensor would be immune from random protective sheets.
Basically, take out the ALS and check the opening in the display for anything in there there could be blocking the light for the sensor.
That's my best guess; let us know what you find.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Remy Stark 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 82
总计 288
