跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153 个问题 查看全部
Leaking on left side of radiator
Where is the leak coming from .I change out filler part and I still see fluid
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@ajmendez1975 could be a leaking hose or a leaking radiator. We really need to see where you are looking it and see if we can guide you further. The best test would be a pressure test. Not sure where you are located so it'll be kind of useless to tell you a store where you can get them from. Just do an online search for Radiator Pressure tester and see if that is something you want to invest in. If not, some radiator places will do this for you, but may charge you.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrew Mendez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 27
