跳转到主内容
Repair guides and support for your Philips TV.
220 个问题 查看全部
water has penetrated the LED screen
Hello and good day. My TV is 47 inch model 47pfl6007h/12 or zh1J1231004048 and water has penetrated the LED screen and this problem has arisen. Please help me.If you can guide me with a picture, which part to replace, my TV problem will be solved. Thanks to the good company Philips.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
alimosavi450 this will depend on where the water created short circuits. For now, do not turn your TV on. Unplug it and remove the back cover from it. Take a look at tall the boards. Check for corrosion and damaged components. Post some pictures of all of your boads, with your Question. Use this guide 在已经存在的问题里加入图片 for that. Also, let us know what happened the last time you ruend it in. If you had a white screen, the issue could very well be that the LCD driver board, which sits on the bottom of the LCD panel, has either shorted out or is corroded. We will need to see that board too. It is attached via some fine ribbon cables to the LCD panel and can't be remove. So be careful around that you do not tear those cables etc. For now, it could be any board that has failed. Most likely it's the driver board or the T-Con board. Missing VGL or VDD voltages on those boards can cause a white screen. Without seeing your boards and eventually having you check them, will only allow us to guess.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alimosavi450 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 30
