How to re-solder usb cable
i found out that my galaxy tab's (7" P1000) usb cable was cut off at the USB extremity (the one that goes into the PC or Charger, not the one that goes to the GTab).
And to fix it i need to know the right order to solder the wires to the usb extremity; i have blue, red, white, and green wires that goes to 4 soldering point.
i hope you understood my problem and will help me fix it,
Thanks
2条评论
So i have found this about USB 2.0 Wikipedia USB
So i wanted to know if i can use the same order as in TYPE 1 USB but using the blue wire instead of the Black one for GND.
i hope i was clear enough
由 Samy Chaabna 完成的
由 sbabljhs 完成的
