跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
426 个问题 查看全部
Does it make a difference if the battery and starter is on opposite si
I went to get a starter at pick and pull and the car was exactly like mine but battery and starter was on passenger side of the car and mine is on driver side does that make a difference?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Librada,
It might make a difference; your Honda came with either a 4 cylinder or a 6 cylinder engine, and it's quite likely the two different engines use different starters.
If you post the year and engine size of your Accord, we can try and look up the specifics of whether the two engines use the same starter or not.
UPDATE:
The only explanation I can come up with for what you're seeing is that the one you're looking at in the Pick 'n' Pull is a four cylinder while yours is a six. Here's a 2.4L from 1998 to 2002, showing the battery on the passenger side.
While a picture of another 2002 with a V6 like yours shows the battery on the driver's side like this.
Assuming that's what's going on, then it's a no go on the starter. The 4 cylinder takes a starter that looks like this.
While the one for your car, the V6, looks like this one.
这个答案有帮助吗?
得分 1
1条评论:
My car is a 2002 Honda accord v6 engine the vehicle was exactly like mine but on different side than mine it was at pick and pull
完成的
添加一条评论
添加你的答案
Librada Barreras 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 29
