跳转到主内容
The Panasonic Lumix DMC-G7 is an entry-level mirrorless interchangeable lens camera released in May, 2015. The camera has a 16MP resolution and is capable of 4K video capture. The model numbers are DMC-G7 in most of the world and DMC-G70 in Europe.
14 个问题 查看全部
Menü and other back buttons doesn't work.
Hello, i buyed the camera used and it got one time opened and the screen cable was not good so I replaced it and it's working now but all back buttons doesn't work.
I can't enter the menu or other things nothing happens. The connector and the flex cable looks good tried 5 times to put in and out the cable but nothing happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It's possible that the issue with the camera's back buttons not working is due to a problem with the circuit board or a software issue. If the connector and flex cable are both in good condition and properly connected, then it's likely that the problem is not with the cable.
One solution you could try is performing a factory reset on the camera to see if this resolves the issue. If not, then it may be necessary to take the camera to a professional repair service to diagnose and fix the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andreas S. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 321
