跳转到主内容
Whirlpool WTW4816FW or the Maytag Centennial washer MVWC415EW2.
15 个问题 查看全部
spin cycle not fully done
Clothes still wet and not spun against side of tub at end of washing. Pump working. New synchronous motor. Belt inspected. Clutch manually engaged when replaced synchronous motor. Seems to work just fine( the clutch).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hi,
Please verify the make and model number of the washer?
完成的
添加一条评论
1个答案
The pump is probably clogged up with a penny or something small.
The pump will still come on but cannot drain. Check the L in the hose on the pump.
Washing machines have a catch all type net or something like that to catch rings,pennies, & such.
I'm no expert but that's what I had an issue with.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan And Monique Carson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 162
