跳转到主内容
Here you will find several different repair guides for the Dell Chromebook 11 (CB1C13) - 2GB & 4GB models
11 个问题 查看全部
chromebook's comma key will not work
a chromebooks comma key will not work and when it does it spams commas until i either pull up on the key or push down hard on the key.
this computer has had hinge damage before if that has a affect on it
does anyone have a idea of whats happening?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @timtomissus,
There isn't a lot to the individual keys on a ChromeBook, and it's fairly straight-forward to check. Follow the Key Replacement guide and pull off the keycap, then check the hinge mechanism and the four metal tabs that secure it to the palmrest.
Dell Chromebook 11 CB1C13 Letter & Number Key Replacement - iFixit Repair Guide
If any of the metal tabs are broken, the only cure is to replace the entire keyboard assembly, but if the hinge mechanism is broken, you can buy individual replacements at several laptop key dealers online. You'll get the rubber cup underneath, the hinge and the key itself. Here's one example.
Dell ChromeBook 11 CB1C13 Keyboard Keys Replacement - ReplacementLaptopKeys.com
这个答案有帮助吗?
得分 2
1条评论:
i actually ended up just removing the key and put it back on, nothing was stuck under it or anything, i guess it just need to be adjusted lol
完成的
添加一条评论
添加你的答案
timtom77 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 186
