跳转到主内容
Repair guides and support for your Philips TV.
210 个问题 查看全部
Some straight lines are apearing and darken image
i've got this problem that when i turn on the tv it have those straight lines apearing like the screen is brocken and its darken in some places but after a while, like if it was after warming up, the tv is fully normal, i dont realy know what can be happening, i have some images that can show what's happening, any ideas?
Update (02/23/2023)
hello friend, i posted the images as you asked, i believe the model of my tv is the 42PFL5603D/12
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@linkoutsider post those pictures with your QUESTION. Edit the question and insert the images. 在已经存在的问题里加入图片
What is the exact model number for your TV?
完成的
添加一条评论
1个答案
最有帮助的答案
@linkoutsider under any other circumstance I would have said this is a backlight issue. Until I've seen the lack of signal on the right side of the screen. This looks like a bad (failed signal) of the panel. You can try and check the LVDS cables and make sure they are not torn, corroded or otherwise damaged. Ultimately, it does look like a bad panel.
这个答案有帮助吗?
得分 1
2条评论:
ooh, i understand, the thing is that after some time it goes full normal you see? but i will check on that and give you some news.
i apreciate your help a lot, thank you.
完成的
@linkoutsider could be a failed capacitor or similar component. Get a can of freeze spray and spray it on the components, one ar at a time. If the picture returns to normal, you at least have the general area where and what to check.
完成的
添加一条评论
添加你的答案
Sh0uz3r 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 47
