跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
What's wrong with my switch?
My Nintendo Switch had liquid spilled on it,the screen has blacked out. It took a while and it came back the there is a problem it still functions I could type I could swipe I could tap on the screen and it will still respond well it works perfectly fine when it's in the docks but when you try to do you can barely see what's on the screen you can tell it's on and it will still work in handheld mode it like the the brightness has been turned all the way down even tho it's actually all the way up.It's so pretty dark you have to have a really close to your face to see but you can't really see what you're looking at.So does anyone know what's wrong with my switch so i can get it fixed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I don't know much about the Nintendo Switch, but what your describing sounds like a damaged backlight, i've seen it before in Chromebooks, and its exactly as you have described it, everything works but you can barely see it. Usually in a computer a damaged backlight means a bent pin or something. Best I can say is see if you can manage to check it out without causing further damages, depending on how comfortable you feel with possibly taking apart the screen.
这个答案有帮助吗?
得分 1
添加一条评论
Tyshaunda, it kind of depends where the water got into your switch. My first guess would be that your LCD has sustained water damage and replacing it will probably fix the issue, but if water got inside and onto the motherboard then there's the possibility of board damage.
Do you have a dock you can plug it into so you can see if it has a picture with a TV or external monitor? If so, that would support the argument that replacing the LCD will get it going again.
Update:
Ah, that's actually fairly good news; it suggests that the LCD itself is the only problem. On the Switch the LCD can be replaced separately from the digitizer (front glass), so it'll be cheaper than the complete assembly. iFixit sells the LCD if you want to support their repair efforts; here's a link to the part you need.
Nintendo Switch LCD: Replacement Display Panel
You can also find that screen available on most of the big retail sites like eBay, Amazon and AliExpress; here are a couple of examples; if you search around you may be able to find one even cheaper.
for Nintendo Switch Screen Replacement LCD Display Panel Repair Parts,Include Tempered Glass
Nintendo Switch Lite Lcd Screen Replacement - Original Replacement Switch Screen - Aliexpress
And of course a step by step guide to doing that replacement would be handy too, wouldn't it? They've got you covered there too.
Nintendo Switch LCD Replacement - iFixit Repair Guide
If you're happy with using it with the TV, there should be no rush to get it repaired; there's a small chance the LCD could recover once the liquid inside finally evaporates; I wouldn't count on it, but it is possible.
There you go; I think you've got all the information you need, so good luck with it and let us know how it turns out!
Replace a damaged or malfunctioning LCD display panel in a Nintendo Switch.图片
产品
Nintendo Switch LCD
$49.99
这个答案有帮助吗?
得分 1
1条评论:
I plugged it up to the TV and it works perfectly fine it's just when I put it in handheld mode
完成的
添加一条评论
添加你的答案
Tyshaunda Crews 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 218
