Ps4 won't turn on, but disc drive has power.
Ps4 model: CUH 1215A
Greetings, recently my ps4 stopped working, at first when I tried to turn it off, it stayed on white light blinking for a few minutes, but then it did not shut off so I unplugged it.
Recently this Ps4 had issues with turning on, it had to be left for a while connected before it would turn on again, so I opened it up and cleaned it. Decided to open up the power supply and found ants in it, to the Ants out & cleaned the areas with IPA.
Now it won't turn on, but the disc drive makes a beeping noise, leads me to believe it is the power supply not sending the correct voltage. I took this Ps4 from a friend who was no longer going to use it, fully knowing it had issues, but because I want to learn how to repair I decided to take it.
Before I start buying parts I would like to know possible problems and hopefully narrow it down to a specific area.
Observed behaviours:
Ps4 disc drive receives power, but won't show go into blue light.
Ps4 the day before turned off after posting into bluelight.
Ps4 after turning it off, went into white light, but would not shut down, so it was manually unplugged.
Ps4 previously had ants in the power supply.
1条评论
I had this problem too but it's just the opposite I have power but my disk drive don't work I just Recently put in a new one any ideas
由 Aaron Van Doorn 完成的
