跳转到主内容
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
43 个问题 查看全部
power goes on but engine will not speed up
Engine works but does not increase speed when the speed dial is turned. continues at very low speed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
peter netsua your A701 uses a speed controller. You want to check on that. Make sure that all the wires are connected, that the capacitors are still in working order and check the triac. Use something like this and some more on here as your guide. Post some images of what you find on yours so we can try and help you further. This Kenwood A701 A701a is the SM for your mixer and should help you with working on this mixer. If you are stuck on anything or you need further help with, post some pictures of where you are stuck with your Question. That way we can see what you see. 在已经存在的问题里加入图片
It's a great mixer and repairing it is definitely feasible and the right thing to do.
Repair is War on Entropy
这个答案有帮助吗?
得分 3
1条评论:
Thenk you very much for taking the trouble to write. Much appreciated
完成的
添加一条评论
Is It possible that the motor is under strain from food building up inside of it the other thing I would do is check if there is any rust inside.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
peter netsua 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 81
