跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Weird sound problem with iPhone 3GS
I replaced the dock connector in my 3GS due to a bad antennae. After replacement I get no sound when watching youtube or videos I have recorded.
However, my phone rings, I can hear/talk on phone calls via the earpiece, speaker phone and headphones
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
I reseated the connectors and restored.... still nothing.
Doesnt even show a volume control on youtube or videos I had taken before.
I press the ringer up/down buttons and it does nothing either.
完成的
You may have not connected the ringer up/down buttons right, reconnect those and exchange the antenna and before the phone goes back together, verify the connectors inside
完成的
I have gotten bad dock assemblies off of eBay. Irritating as it may be u could have gotten a bad part
完成的
添加一条评论
1个答案
已选择的解决方案
Try rseating the connector
If that is no help, it is a defective part or another part is bad in the phone
Let the phone do a backup if that does not work and restore it
If that is no help, it is going to be something to do with the logicboard
How did i come up with this?
I ruled out a new dock connector, then i thought a restore could do something, and yes i thought ahead that it's hardware in the phone somewhere
All a iPhone is a battery, dock connector, logicboard, earpiece, digitizer, screen, proximity sensor(s)
update
Although you recently restored, you may have to again, you may want to reseat any connectors in the phone first
这个答案有帮助吗?
得分 1
2条评论:
The restore on the phone was a few days old (not used at all however other than making sure everythign worked)
It worked before I replaced the connector, just not now.
I was under the assumption that the external speaker is what would be bad, but It does work on speaker phone. Am I wrong about this?
完成的
Reseat the connector then if that is no luck, I would try another restore, then update your question with the results of that
完成的
添加一条评论
添加你的答案
Andy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,143
