Why does my camera say error code:02400001 and won't work properly?
My camera says error code: 02400001 and won't work properly how can I fix it I'm tech savvy and I can fix it if I just knew exactly what to do.
Hi @johnratliff1982,
Try starting the phone in safe mode and check if the camera works OK.
If it does then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit. A downloaded app is one that you downloaded and installed on the phone, not one that was installed already when you first got it.
If no good try reflashing the firmware using Moto's rescue and smart assistant tool and check.
If still no good it's a hardware problem.
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 115
总计 2,156
Front camera not working
由 You 完成的
Camera nhi chal rha hai
由 Rahul Ptdr 完成的
Motorola one fusion placesCamera is not workingThis error comingA rear camera isn't working Some modes arent available. Top GET HELP for further assistance.
Error code: 02400001Please help me
由 MD ilyas Hussain 完成的
Error code: 02400001Please help me harsh kumar
由 harsh thakur 完成的
Can you please help me
由 anubhav rai 完成的
