跳转到主内容
加入维修社区 - 创建账户
代号为 A34 的第六代 Maxima 仅在美国、加拿大和墨西哥销售。该车型在 2003 年北美国际车展上以 2004 年款的身份正式亮相。
I have a 2008 Maxima 3.5 that won't crank.
I just got the car last week and they had almost no power at all, for example if I would hold the gas pedal down a quarter of the way it had more power than all the way down. When I shut it off it took a lot of effort to turn back on or I would have to get a jump start to turn it back on. I thought it would be my crankshaft positioning sensor but I just got a new one from the junkyard and it's still not working. Somebody please help me this is my only source of transportation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
If the engine runs, it's not likely to be a crank sensor problem. A blocked (disintegrating internally) catalytic converter (or several) can choke off exhaust flow as the equivalent of engine constipation. A simple test would be removing the upstream O2 sensor(s) on the exhaust manifold for an alternate exhaust path. If the engine starts up (loud) and a brief drive around the block reveals renewed power, the catcon(s) are damaged. Another issue may be a worn out fuel pump requiring testing with a fuel pressure gauge connected to a fuel rail test valve. You'll need to know fuel pressure specs with either ignition on (immediately) or with engine idling).
完成的
添加一条评论
1个答案
Hi @eric1991phx
Here's an image taken from the Starting and Charging system section of the 2008 Nissan Maxima Model A34 Service Repair Manual, that may help.
A description of the starting system is on p.SC-10
(click on image)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 349
