跳转到主内容
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
72 个问题 查看全部
Smoothing burrs on Iron surface
I bought an expensive iron with a Teflon coated ironing surface. Between children/pets it was knocked off a stable countertop hit our hard floor, and now has several tiny "burrs" in the metal of the iron plate. Now when the cloth hits that spot it pulls and tears because it isnt smooth. What can I use to smooth this effectively without causing more damage or creating other issues?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Best course of action is using fine grit sandpaper. But that will remove the Teflon coating but you can find many guides online on how to reapply it to a cooking pan which should be a pretty similar technique. You also could just live without the coating if you don’t want to deal with reapplying.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Naomi Cullup 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 34
