跳转到主内容
苹果公司的 2021 款 iPhone 于 9 月 24 日发布,配备 6.1 英寸 OLED 显示屏、双 1200 万像素摄像头系统和五种可选颜色。该手机为 iPhone 12 的继任者。
93 个问题 查看全部
iPhone microwaved - now vertical lines on display
Hi, My brilliant daughter thought it a great idea to put her iphone in the microwave whilst facetiming a friend!! Result is the phone powers up but has vertical lines across the screen which means I cannot unlock it to get the data off. Where do I start for repair? New screen or is it the devices that drive teh screen? Only want to get her pictures and videos off at this point.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
Hello, could you please add a picture of the device's damage? 在已经存在的问题里加入图片 I also believe that it would be very helpful to the repair process to know why the phone was microwaved. Was the phone water damaged at some point?
完成的
If you plug it into a computer is it detected?
完成的
添加一条评论
2个答案
最有帮助的答案
New screen probably, damaged by the microwaves (take it she cooked it). Take it to a shop and ask if they can hook up a new screen and see if it works before committing.
这个答案有帮助吗?
得分 5
1条评论:
To add to this answer, you can also replace the screen by following this guide. iPhone 13 屏幕更换
完成的
添加一条评论
Microwaves are a form on electromagnetic radiation. Although they aren't ionizing, they can induce high voltages in the chips and wires inside the iPhone, therefore frying them. Considering the fact that the phone still boots, it is likely that the screen was the only part damaged.
iPhone 13 屏幕更换
iPhone 13 Screen
iPhone 13 Screen图片
产品
iPhone 13 Screen
$208.99
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
mike 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 14
总计 154
