跳转到主内容
苹果公司的 2021 款 iPhone 于 9 月 24 日发布,配备 6.1 英寸 OLED 显示屏、双 1200 万像素摄像头系统和五种可选颜色。该手机为 iPhone 12 的继任者。
93 个问题 查看全部
I can’t hear phone calls unless iPhone is on speakerphone how to fix?
iphone13 can only hear phone calls on speaker or other audio device. I have run through a lot of suggestions online. Going to reset to factory defaults. I’m concerned it is a hardware issue. How do I trouble shoot solutions before taking it to shop or opening phone up?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would have a look at the iPhone No Sound troubleshooting page. But chances are there is an issue with the receiver speaker (earpiece speaker).
I would see if you can isolate which functions work properly. Try and play some media and set the balance entirely to one side or the other and see if that effects the sounds. That speaker will also function as an amplified speaker for playing media in stereo. It may just be the speaker grills are all gunked up.
The receiver speaker (or top speaker as Apple calls it) on these is no longer attached to the display, and if I recall correctly it takes some doing to get at if that turns out to be the issue. I believe the logic board has to come out to remove it.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Joseph Lopez 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 33
过去 30 天: 152
总计 5,264
