跳转到主内容
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79 个问题 查看全部
Why does audio not work on right side when using jack?
When the audio is being output via bluetooth, the sound comes from both sides and is very clear. When I try to use it with the provided cord, the right side does not produce sound and the left is significantly quieter.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@flyingmoons either a bad jack or a loose wire on the cable connector. Try a different cable and see if that works. If it does you know it is the cable. if it does not, it's the jack.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
June J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 17
