跳转到主内容
Released February 2005, model number DCR DVD103. Has 20x Optical zoom and 680 KP.
6 个问题 查看全部
Can you eject the tape without power?
The camera has quit on me and I tried a new battery, using DC power and it won't turn on. My IT guy is going to look at it, but in the meantime I really really need the tape inside the camera. Is there a failsafe to eject the tape?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
cindy, really not much of a tape, since it is a DVD. Anyhow, according to the service manual you can:
3. TO TAKE OUT A DISC WHEN DISC COVER DOES NOT OPEN (FORCE OPEN)
1 Remove the cabinet (upper) assembly (E).
2 Remove the cabinet (R) assembly.
3 Remove the VC heat sink, VC radiation sheet.
4 Remove the lens section, F panel section.
5 Push the portion A in the direction of the arrow and open the disc cover.
you can utilize these guides Sony Handycam DCR-DVD103
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
No, it is motor controlled via power. Your tech can probably take apart the outer housing and retrieve the tape first, then move on to find the problem with the camera. ~ please don't try the hammer and fury method ;)
这个答案有帮助吗?
得分 3
添加一条评论
Can you eject a tape from a sony handycam DCR-109E without power. If not how can you do it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cindy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 74
总计 10,357
