跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
charging port isn't charging, is it mean that the battery is dead?
I intend to repair it, to see if I am capable of doing so for my future career. I have some experience with repair, but not entirely 100% yet.
After I removed the screen, I noticed there was a black spot with a ring surrounding it. Does it seem like it's the spark from the battery? I assumed that the battery need to replace with a charging port. I just need someone to tell me if I'm correct or if I'm wrong.
I would appreciate your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you've got it open for sure replace the battery. Go carefully, they are glued down and be cautious if you're using a heat gun to loosen up the sticky compound.
The charging port is likely filled with lint. Use a small pin/needle that can get down in there and just go gently scooping out all the debris. Get a light shining down in there too and make sure you don't have any fragments stuck or shorting out something.
FYI, you may have a more major issue at hand and if this basic troubleshooting doesn't resolve your issue you may need a new charging port or deeper investigation to see where the issue lies.
这个答案有帮助吗?
得分 0
1条评论:
I will do the battery replacement first task to do before go to the next, a charging port. I will let you know how its goes after I am done and thank you for a quick replied with advice.
完成的
添加一条评论
Hi Albert,
Yeah, that spot on the display does look as though it may have been from a spark from the battery. It's a little hard to tell from your picture, but if it is from a spark, there should be a corresponding mark on the battery itself in the same spot that would have been against the display; it appears there might have been one.
I agree 100% with Combat x Computers regarding replacing the battery and cleaning the port. Your strategy is sound; if the battery by itself doesn't fix the issue then the charging port should be next.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert Casanova 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 30
