跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iPhone 4 doesn't charge, but loud speaker works?
Hello, I helped my sister fix her iPhone 4, as it showed the "Not Optimized for this Device" even though nothing was plugged into the dock. It turned out there was corrosion, so I replaced the dock with a new one. Everything went well, everything worked until I tried to charge it and nothing happened! :o The loud speaker, however, still works, though! What could be the problem? Thanks :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The iPhone 4 dock and speaker assembly are 2 completely different parts. Before the 4, it was one unit but they separated them starting with the 4's. It could be 1 of 3 things that I can think of.
1) The replacement dock is defective. It's happened to me a number of times where a new replacement part is defective which is frustrating as all heck.
2) The connector isn't connected to the board completely. The dock connector has always felt weird to me when plugging it into the board.
3) There is a short on the board somewhere. If this is the case, get a new phone. Buying a new logic board is ridiculously expensive.
Just go through everything that you did and recheck all the connectors. It might help to get a magnifying glass and really inspect the connectors and the inside of the dock to see if everything looks as it should.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
You may have shorted the battery. Grab a multimeter and give it a check. Also, if the battery was shorted but has a "bit" of connection plug the device into an AC adapter and cable and wait about 10 minutes and give it a shot.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
D D 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 592
