跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
Changing dispaly and I dont no were I should work at.
Hello!!
I am changing the display and I have heard about static electricity shocking the inside of the iPhone, I wanted to no if this is a big problem or if i should not be worried about it. Also does anyone have an idea were I should work when I do this repair if the static electricity is a problem? Also I do not have the static safe drivers and wanted to no if simply touching them to a piece of metal would ground them enough to not shock the phone inside's? Any information on this subject would be great and very helpful.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
I've done hundreds, always out in the field (Starbucks, people's work places, in my truck) and have never had a problem arise from not grounding myself. Static electricity buildup is rarely a problem nowadays and if you're concerned about it all you have to do is touch a piece of metal before you touch the inside of the phone and it'll discharge anything you may have built up.
这个答案有帮助吗?
得分 2
1条评论:
I follow the same rules as magistry, maybe not on the same scale..but after a hundred repairs of iphones/ipods/radios/tv's/laptops/ds/playstation and xbox I haven't encountered any problems with ESD... At the end of the day it's your phone and you should treat it with respect and follow at least the basics of ESD. In these cases I think pulling connectors off logicboards is the most common error a repairman makes!
完成的
添加一条评论
添加你的答案
kaine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,171
