跳转到主内容
The 2014 edition of the Kindle, part of the 7th generation, includes a touchscreen and same form-factor as the Kindle Paperwhite, but lacks the backlight.
29 个问题 查看全部
Kindle 7 replacement part availability
Does ANYONE know where I can order a replacement headphone jack for a Kindle Fire. It measures 7" diagonally across the screen so I guess it is a 7. I can't seem to find a replacement part on-line. Not even sure if they make them. About ready to MacGyver the end of a 1/8" audio extension cord into it with some high strength epoxy. It'll be ugly but it'll work. Someone please help before I have to create this monstrosity. :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @badger62.
What is the model number of the tablet (found on the back cover)?
The best way to find parts for Kindles is by using the model number and not their model name as it leads to confusion between the different names and generations if you do as the parts are nearly unique to each tablet series.
Another option to consider is if the tablet has Bluetooth, you can connect using BT headphones (if you have a pair)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Whitney Tustin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 37
