跳转到主内容
Standard and high definition handheld video cameras by Sony.
116 个问题 查看全部
Sony CCD-F330E camera viewfinder problem
When I select camera mode or REC mode the view finder Lcd screen just flickers like a old tv
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
@iphone897 is it still recording? What are the recordings like? Same thing?
完成的
I can’t see what I’m recording its still able to record but the viewfinder is having display issues
完成的
添加一条评论
1个答案
最有帮助的答案
@iphone897 since you can still record it sounds like the issue is isolated to the viewfinder. Possibly a bad display. Start off with the SONY CCD F330e service manual. Disassemble the viewfinder and check the circuit board and ribbon cables that connect it. If this look okay I would try a replacement viewfinder CRT next.
Update (01/27/2023)
Here are the part numbers
1-451-310-21 Deflection yoke
1-546-065-11 Cathode Ray tube
use the part numbers to do an online search and you may get lucky like on here
这个答案有帮助吗?
得分 1
7条评论:
If I were to get a viewfinder replacement where would I look to get one?
完成的
@iphone897 yes checking on that as well. Darn, it surprised me that it uses a CRT for the viewfinder. It is like an old fashioned TV:-)
完成的
Behind the battery there is a small silver cr2025 battery can anyone tell me what that’s for?
完成的
@iphone897 that is your RTC battery. It makes sure that your Date and Time are right as well as it help to maintain your settings.
完成的
What powers the viewfinder the cr2025 battery of the main battery as I take out the cr2025 battery and the clock is still in there?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Ryan white 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 116
