跳转到主内容
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
224 个问题 查看全部
What is the name of the CB300 Chip for replacement?
Found a defective CB300 chip and removed it removing the problem I was facing, looking to identify the chip to order a new one.
Update (01/26/2023)
It's an 820-00239 I've circled the chip in the photo hopefully it's zoomable (it's small)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
hi rich, can you tell us the board number 820- and add a photo of the area
完成的
have updated now
完成的
添加一条评论
1个答案
已选择的解决方案
Is it CB300? Or CB308 (which is the one you circled)? CB300 is the one under the little tab in the photo. And that sucker is a magnet for a tiny bit of liquid damage.
Ultimately it doesn't really matter because it looks like both of the components in question are 10μF, 6.3V ceramic capacitors in a 0402 package. Realistically, it is not entirely necessary to replace this capacitor. It may have some minor effect on the longevity of the unit, but if that was the fault, the computer should work just fine without it. Replace it if you are able to do so safely.
这个答案有帮助吗?
得分 3
2条评论:
Thanks for help! it's the CB308 as circled, I was mistakenly referring to it as the CB300.
完成的
@Rich Kent No worries, just wanted to make sure I was in the right neighborhood! Happy fixing!
完成的
添加一条评论
添加你的答案
Rich Kent 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 37
