跳转到主内容
Repair guides and support for your LG TV.
1336 个问题 查看全部
Lg 55 in powering on has a black screen then powers of by itself
I have a problem where my tv will power on when you hit the remote power or the button on the tv the light on the bottom will come on for a couple seconds with a black screen then it will flash the backlight and power itself off what could cause this????
Update (01/24/2023)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
mjzot could be your backlight that is preventing you TV from coming on. Power board or backlight array would be possible. We need to know the exact model number for your TV as well as seeing the boards. Remove the back cover and take some good pictures. Post those with your question 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
mjzot first you need to rule out your inputs as error causing. Remove all of them (especially if you have some sort of cable box, sat box etc.)Unplug your TV and unplug all input sources. Hold down the power button for 30-60 sec. Then reconnect one input source (preferably local like Game console, DVD/BR player). and make sure you use a known-well HDMI cable, if that's how you connect. Lastly reconnect the TV and try to turn it on. See if that changes anything.
First off my suspicion is that this is caused by failed backlight strips. LG LN series has a high backlight failure rate.
Try this. Disconnect the T-con board, unplug the TV and plug it back in and turn on to see if backlights are visible through the small holes in the back panel. The backlight should come on by unplugging the power cord and then plugging it back in with the TV on. The T-con board is the one under the small metal cover that has the flat ribbon cable from the main board connected to it. Center bottom on your picture.
One more thing to try, with everything else back on, would be to disconnect the backlight.brown board, top connector, small cable going into the panel (top center) and then start your TV. SEE if the start up behavior has changed.
Next remove the back from your TV ;-) Get a multimeter and get the Voltage readings on the power supply connectors that go to the main board. Measure those with the TV OFF and then measure again with the TV ON. OF importance is the voltage on the PWR-ON (PS-ON) and DRV-ON (BL-ON)? You should get 12V/24V when PWR-ON signal from main board is present. After that you will get back lights when PWR-ON, DRV-ON, and PDIMs are present. Okaty, now let us know what you find out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mjzot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 114
