跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Very slow charging and always show 100% battery
Hello from Norway. I was hoping someone could point me in the right direction on my battery problem. Storie goes like this: Had to replace the battery and follow the directions from ifixit. everything work fine for 2 days, but then it starts to charge the battery very slow. from 0-100% it takes around 13 hours. and the icon showing battery always say 100%. It works perfect running on battery, but only for about 1 hour and then the battery is empty. Putting the charger back it starts, but works very, very slow until i get more then 10% battery.. any suggestions on what i can do?
( I have tried al the normal things like calibration and smc reset )
Thank you and best regards
Truls.S
Update (01/22/2023)
Sorry if this is the wrong way to do this, but here is a picture..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Let’s get a better view of things, install this gem of an App CoconutBattery take a snapshot of the main window with the battery section opened here so we can see things.
这个答案有帮助吗?
得分 1
5条评论:
Thanks for your reply Dan. I have updated my post with image.
完成的
@truls75 - You’ll need to contact the iFixit store this Batteries micro-controller is messed up! Clearly, the battery can’t be older that your system, 2015 for your 2017 system.
完成的
Look at that.. That can be a problem yes.. Just to clarify, this battery is not bought from ifixit, so its not their fault. But i will definitely contact the store i bought it from. Thank you for helping me take a look at this Dan.
Appreciate it 👍
完成的
@truls75 - Well at least in this case not 😁
Don’t forget to score the answer and accept it - Thanks!
完成的
@danj 😊 Thanks for helping me out.
完成的
添加一条评论
添加你的答案
Truls Solberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 102
