跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1123 个问题 查看全部
What's wrong with this display?
My display was working all fine until two days ago. Suddenly, the colors started looking bleached, the contrast is weird and the display will show traces of things that aren't on screen anymore.
Other things I tried: when I plug an external display the second display works fine, but the primary screen stays bad. I tried to reset SMC and PRAM already.
Pictures:
Login screen: you can notice that the image looks weird. The "enter password" field is less readable than normal.
If you open TextEdit, which has a white background, you can see a "ghost" of the login screen:
Other windows, and specially shadows, look weird, the image has some stains:
Question: is it the case of changing the whole display (expensive!) or could it be just some connection cable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
From what I have seen it could be ether the screen or the cable
From my experience aslong as the screen has hasn't had a drop its probably the cable as i have seen Macs do this before when the cable starts to fail
Heres the guides for replacing the cable
Cable starts a 6:45
https://www.youtube.com/watch?v=9wjgF8j2...
And heres the one for getting the screen off
MacBook Pro (13英寸, 带有Retina显示屏, 2015早期) 显示组件更换
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Esdras Beleza de Noronha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 17
