跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2683 个问题 查看全部
Why do randomly I lose control of the screen?
Every so often, usually once per day, I will be using my phone and it will, without my touching, swipe around and puch buttons on the keyboard and I will have absolutely no control and it has sent weird messages to my friends. This is the weirdest thing I have seen on a phone. This wasn't a problem before, but I cracked my screen and took it to a repair shop (my parents would let me repair it myself) and when I got it back this glitch started happening. Does anybody know what this is and what I can do? I am very confused.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hello! I've experienced a similar issue like this. You might have tried a few of these things already so you don't have to follow the steps in order. Here's what I would recommend.
1.) While it may seem obvious or stupid, try cleaning the device with a damp, microfiber cloth. If you can't get ahold of one, a paper towel will do. Unplug the device, shut it down, and gently wipe. Based on your issue that likely won't solve it, but it's worth it for the following steps.
2.) If you don't have a screen protector, skip this step. However, if you do, carefully take it off. Repeat step 1 again but you likely won't need to be as particular with it.
3.) If you don't have a hard case, skip this step. Sometimes if you drop a phone in a hard case, the case will bend. This can affect the screen and cause further issues with the responsiveness of the display. Just taking off the case might do.
4.) Force Reset your device. Apple explains it fairly well here. Select whatever iOS version you're running. It can't be iOS 16.
5.) If the problem still continues, I can almost guarantee that your issue was caused by a bad repair job. If the job was rushed, improper seating of the display cable as well as a dozen other issues from faulty repair/parts can cause this. I would personally repair it myself, but if you can't in your current position, I would see if your parents can bring you back to the repair shop or another one available. While most technicians know what they're doing, it's entirely possible for a few negligent ones.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Dimitri Cooper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 56
