跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
559 个问题 查看全部
Internal drive doesn't show up in Disk Utility during Recovery Mode?
My internal drive is a 500gb OWC drive, inside of my late-2013 MBP. I can turn the laptop on, login, use it, and open disk utility, and it shows up.
The issue is that I want to wipe this device and reinstall MacOS. I've logged out of all accounts, reset nvram, and booted into Internet recovery mode, and that's when I run into an issue. Disk utility while in recovery mode no longer shows my 500gb OWC drive. It shows "disk 0," which shows up as a drive with 1.28gb of space. Nothing else. My functioning OWC drive doesn't even show up in the terminal when using "diskutil list".
Trying to move forward with the "Reinstall OS X" option leads me to a prompt asking me to "Select the disk where you want to install OS X." Beneath that, there are no options. It's just blank, like no hard drive exists in the computer.
I've tried looking for other solutions on the Internet, but everyone with this problem has a dead drive. My internal drive is not dead. It's working. I restart my laptop after this issue and boot back into macOS, where I can log back in and the drive functions perfectly fine - all my saved files are there, all my apps run as normally, and the drive reappears in Disk Utility.
Any advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hi
Have you tried reformatting the drive in disk utility?
Most new drives come formatted as FAT32 and you need the drive formatted in macOS extended journaled I order for it to work
完成的
@hellomacos Hi, thanks for the response. The drive is formatted as APFS.
完成的
@oni0
When you click/hover on the SSD or disk0 in your case do you get the option to open a drop-down menu?
完成的
添加一条评论
1个答案
最有帮助的答案
This is a common issue in this series as Apples recovery server offers out the older HFS+ versions of MacOS and the version of Disk Utility has no idea about APFS volumes as well as have the needed PCIe/NVMe drive you are using.
So you need to setup an external drive with recovery service, then upgrade it to what your drive had on it (if already used) or just prep the new blade SSD drive using the upgraded external drive Disk Utility and the OS installer you used to upgrade it.
这个答案有帮助吗?
得分 2
2条评论:
Would I be able to run off that external drive and wipe the OWC drive from there?
完成的
@oni0 - Yes, a bootable external drive also works.
The issue is you need something external that has the newer Mojave or newer macOS on it.
Most people don’t have a drive setup beforehand and may not even have a drive, a cheap 32GB thumb drive is all you need.
完成的
添加一条评论
添加你的答案
Onio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 77
