跳转到主内容
Gateway laptop identified by model #MT3707
6 个问题 查看全部
My Gateway MT3707 laptop fails to power on. Why?
My Gateway mt3707 laptop will not turn on.
I first started thinking it may be the ac power adapter had failed. So, I ordered a new universal adapter. It arrived in the mail and as soon as I plugged it in to the laptop I noticed the LED indicator on the front bezel lit up purple indicating the battery was charging. I pressed the power button and the laptop started with no problems. I had to leave at that moment and came back later that evening to work on transferring some files around.
I went to log in at the Windows log in screen and found the keyboard was not responding to any key punches. Then randomly I would get a few letters to punch. I guessed that the system needed a restart from sitting too long so using the mouse I clicked the restart command from the menu on the log in screen. I waited several minutes and the computer never attempted to restart. I figured the system had locked up even though the mouse was still moving so I pressed the power button to issue the restart command that way. Nothing happened. I then pressed and held the power button to turn off the laptop and still nothing happened.
I ended up removing the universal ac adapter and the battery to completely remove power from the system.
After a minute, I replaced the battery in it's slot and plugged the ac adapter back in to the laptop. No charge light indicator came on and the laptop would not power on. I removed the battery and the ac adapter again and let the laptop sit all night until the morning.
In the morning, I replaced the battery and also plugged in the universal AC adapter. The charging light for the laptop came on. I then checked the original ac adapter also. In the process of switching adapters, I noticed while the adapter was not plugged in to the laptop the charging light remained on.
And that details to where I stand now with my broken laptop. It is still plugged in, with the charging light still on. I have not attempted to turn the laptop on, yet, while I am seeking answers.
So far my best guess would be the motherboard or charging circuit has an issue? Is this laptop beyond repair?
Update
It has been well over a week since I last attempted to mess with it. It never did power back on even after attempting to remove power, hardware, etc. So I will be buying a new laptop. Appreciate the answers that were given, though.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi there,
Was this ever resolved?
- Nate
完成的
With my Gateway Lap Top I have a problem trying to open with my password. What works is I shut it off and take out the battery for a couple of seconds. I put the battery back in than I can put in my password. I hope this help if you can not open with your password. Emma.
完成的
添加一条评论
4个答案
已选择的解决方案
A common power problem with laptops is the DC power connector gets loose on the mother board - fractured solder joints. It may be worth opening up the laptop and checking them as a start
I cant find a manual or a specific guide but the links below may assist you in opening up the device
LINK 1
LINK 2
HIH
这个答案有帮助吗?
得分 1
1条评论:
You can get the M-series service guide from here
完成的
添加一条评论
最有帮助的答案
I had the same problem this worked
try doing a hard reset what that is is removing your power sources and holding your power on button for 60 seconds then connect your ac adapter then power on- if that doesn't work try reseating your ram and your hard drive otherwise you may have a real problem
这个答案有帮助吗?
得分 2
1条评论:
I did this, and it worked! Thank you so much!!!
完成的
添加一条评论
Hi
Some times this problem happend becaous wrong with hard drive or ram, you have to unpluge ram one by one and turn on laptop ,if nothing happend you have unpluge the hard drive and try to turn on the laptop the screen will show you message with some notice, if nothing happend of that you have problem with motherbord or CPU.
这个答案有帮助吗?
得分 1
添加一条评论
I had this problem and I just replaced the power supply and all was well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelly Louwers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 7,606
