Why is my dryer continually running
My dryer continually runs the control switch does not advance and now doesn’t heat
Hi @karenje
Most likely the problem is with the timer (supplier example only). The heater circuit is also affected by the operation of the timer contacts.
Here's the wiring diagram for the dryer, so you can test if the timer and heater circuits are OK or not.
If the timer is faulty search online for WP3979617 to find suppliers that suit you best. Here's a video that shows how to replace the timer that may help
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 42
