跳转到主内容
任天堂于 2021 年发布的 Switch OLED 机型的维修和拆卸指南。
33 个问题 查看全部
My switch won’t connect to my tv
My doc charges my switch, and works on my old switch as well. When I put it on the doc to play on my tv it don’t show. I watch YouTube and changed the revolution and still nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
This sounds like it could be an issue with one of two things. Since we know the dock works with another switch it's most likely the charge port or an issue with the motherboard.
Although the USB C port on the bottom is responsible for both charging the Switch and outputting the display, it is possible that it might be able to do one, but not the other. Have a look into the port with a flashlight and make sure there is no debris, and all the pins on the port seem straight. If there are any that are bent, they can be straightened with something thin, and non conductive. A toothpick might work, though you might need to shave some of it off so it will fit in the port. Just avoid using anything metal for this operation without disconnecting the battery first.
If not the port, then likely the USB/Displayport chip which is responsible for video output. On the attached image, it is the chip outlined in red. It is one of the more common faults with the board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Moiswa 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 20
过去 30 天: 42
总计 616
