跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
164 个问题 查看全部
No signs of life, draws power from wireless charger but not wired
My friend's iPhone 12 shows no signs of life (nothing on screen, no charging noises/vibration, etc.) I don't have a USB power meter but I have a kill-a-watt style meter. Using that with an Apple 5w charging brick shows the phone sometimes drawing about half a watt for a second at a time, but ultimately not drawing any power. (I cleaned the charging port and nothing changed.) With a wireless charger, the meter shows about 6 watts and the light on the wireless charger is on, signaling that a device is charging. I left it on the wireless charger for about half an hour and it kept drawing power, and got hot (I don't know if it would normally get as hot as it did, I don't use wireless charging for my devices) but still didn't power on.
I opened the phone and tried to measure the battery voltage with a multimeter, but got 0v. However, I couldn't find a pinout online so I might not have been measuring it on the right contacts, but I tried all the contacts I could.
I was thinking it might be a battery issue before I tested with the wireless charger but now I fell like it could be something else. I don't have much experience troubleshooting this kind of issue, so any advice will be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello!
Based on the information you provided, it is likely that the issue is related to the battery. If the multimeter reads 0v, then the battery is likely not providing any power to the device. This could mean that the battery is completely dead, or that there is a fault somewhere in the charging circuit.
You can try replacing the battery to see if that resolves the issue. If not, then it is likely that there is a problem with the charging circuit.
I hope that helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CalvinF 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 39
