跳转到主内容
苹果 2021 年的顶级智能手机。iPhone 13 Pro Max于9 月24日发布,配备6.7英寸ProMotion OLED显示屏、新的三颗后置摄像头系统和 5G连接。iPhone 12 Pro Max的继任者。
31 个问题 查看全部
If dropped in fire and screen slid off could I get new screen and it w
My phone dropped in burning pile, when i finally realized what had happened, i dug in the ashes and found it, the screen just slid off phone. To my surprise, my phone is still working, i have been getting notifications, and phone is ringing. If i replace screen should that be all i need to do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Wow, sounds like you're one lucky person!
It's definitely possible. You might find other issues once the display is replaced, like cameras or microphones, but I'm sure your display didn't appreciate the heat. If you want, edit some pictures into your original post and we can have a look at the internals to try and determine how likely you are to encounter other issues. But it sounds like the logic board at the very least is functioning as intended.
这个答案有帮助吗?
得分 3
3条评论:
How can i add pictures?
完成的
@rvservice you can click edit on your original question and there should be an option to attach pictures. There's a guide as well if screenshots help to visualize
完成的
@rvservice Oh wow! That’s not what I was expecting at all. It looks like some of the layers of the display came delaminated, but not all of them. I was expecting the display itself to have come altogether. But I suppose this makes more sense.
The Face ID assembly definitely looks a little worse for wear. I wouldn’t trust that to work for sure, even though I can see some parts firing off infrared light. If you’re feeling really adventurous, and have a pentalobe P5 screwdriver to remove the security screws at the bottom, I might try to get the rest of the display out and see what the internals themselves look like. At least you don’t have to worry about breaking the screen? Just be mindful of the battery.
I’m not sure how functional you want the phone to be. No Face ID or front facing camera is one thing, but phones have a whole lot of bits and pieces.
完成的
添加一条评论
添加你的答案
Shimmer Shine 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 90
