跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
63 个问题 查看全部
Can’t find the relay in a Vauxhall corsa E?
My blowers aren’t working in my car. We have checked the motor and that is working. The fuses are good. Now we need to relocate the relay to check that. Where would we find the relay in a Vauxhall corsa 17 plate?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
From Haynes, "... in the underhood fuse block there is a 40A cooling fan high speed relay at positions 41 and 45 and R6 , with a 30A cooling fan low speed relay at position 44 and a low speed relay at position R8". This would be fairly similar across most variants, but if you can provide an exact year, engine capacity, model number, etc to confirm? This is a common diagnosis, but the issue may instead be solved by changing the temperature sensor or repair the engine computer. Relays can be opened up and the contacts cleaned by pinching and sliding a business card through them.
这个答案有帮助吗?
得分 1
1条评论:
Vauxhall corsa 1.4 energy ac eco flex
1398cc, 2017 plate, W0L0XEP08H6052303
完成的
添加一条评论
添加你的答案
Katiejames123 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 257
