跳转到主内容
Improved second generation Google-branded tablet with a 7" screen.
97 个问题 查看全部
Google logo comes up, then nothing.
Same issue, after at least a year in a desk drawer, charged overnight, hit power button, Google logo comes up, then nothing. Tried the power plus volume down buttons, the correct screens come up (Android with open door), scroll to recovery mode, hit power button, screen goes blank, then Google logo displays then nothing, just nothing, just the logo.
Anyone with suggestions, please!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
So with the power off, you pressed and held the power and volume down buttons and the large Android with the open door appeared. You scrolled to "Recovery mode" hit power button, screen goes blank, then Google logo displays. After a wait did the little Android with open door with "No command" text under it and nothing else not appear on the screen?
If you did then that is where you hold the Power Button down and tap the Volume Up.
The Android Recovery screen should come up. Then you can select Wipe data/factory reset.
If not have you tried disconnecting the battery? This is like a hard reset.
Have you checked inside that all connection are correct and secure?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John Attanas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 22
