跳转到主内容
The Maytag model LDE8604ACE is a gas dryer produced by Maytag.
16 个问题 查看全部
MEDC465HWO Dryer won't heat or rotate.
Maytag Electric dryer won't heat or rotate. It's not the thermal fuse door switch start switch or any of the three thermostats. They all passed a continuity check. The light works and you can hear the timer doing it's thing (or possibly broke). I've verified the current at the power block also. The belts not broken rollers are fine the dryer is only a little over two years old. Whats next? Model is MEDC465HWO
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @williamhenry
Looking at the wiring diagram for the dryer it could be that the timer is faulty, maybe check if timer contacts B - C are closed as these affect both the motor and the heater circuit.
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
2条评论:
Timer tested good at least in regard to B and C being open when off and closed when on. So the main thing keeping me from expecting the motor to be bad is the heat. Wouldn't the element still heat if everything was working but the motor?
完成的
@williamhenry
If you look at the wiring diagram, the heater gets power through the motor centrifugal contacts 2m -1m so the motor needs to be turning for them to operate.
Is the motor humming trying to start?
If so check if the motor starts turning it you rotate the drum by hand to help it overcome the inertia.
Be careful when you try this ;-)
If it starts and runs then the start winding is open circuit.
完成的
添加一条评论
添加你的答案
William 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 58
