跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
Internal keyboard not working after battery change
Hi guys
First time posting here, thank you all in advance! So I recently changed the battery on my 2015 Macbook Pro.
Upon booting up the machine, the built in keyboard is no longer working.
Trackpad works 100% fine, power button works fine and keyboard is backlit OK.
Re-opened the machine and it appears that the keyboard connector is bedded properly with the latch closed.
I've seen some posts that suggest checking for software updates etc, but I don't think this is the case.
Also seen some posts saying that the keyboard connects to the motherboard VIA the trackpad, something I don't fully understand if there's a connection which seems to go direct from keyboard to motherboard.
Any help or suggestions on how to fix this would be very much appreciated!
Thanks
J
Update (01/06/2023)
Thanks for that advice! I've just taken some screenshots. Using wireless keyboard and trackpad.
I'm not really sure what it means! Any further help gratefully appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Apple over the years have altered how the keyboard and trackpads connect to the logic board. Some series have discrete connections whereas others daisy chain keyboard to trackpad to then logic board.
So don’t get to lost on what the others do focus in on how yours works. In your system each connect to the logic board independently via separate cables as you can see in this guide on Steps 27 and 33 MacBook Pro 15‘’Retina显示器2015年中期主板交换
So here it’s likely the cable is not squarely inserted.
这个答案有帮助吗?
得分 2
5条评论:
Thanks for this. I've checked multiple times and I'm really sure that the cable is inserted properly. If this is true, what would you advise as the next step?
完成的
@jacksonlapes - mmm… While the cable connections are discrete, both electrically connect to a common internal USB hub.
Using an external keyboard & mouse, go to the About This Mac and click on the System Report to check the USB hub and what is showing up.
完成的
@danj Thank you so much. I've just added some screenshots in a reply below, couldn't post an image in this reply section!
完成的
@jacksonlapes - Well the driver is working so that only leaves the the touchpad cable which is messing up the keyboard data (shorted to ground).
Time to replace it MacBook Pro 15" Retina (Mid 2015) Trackpad Cable
完成的
Thanks Dan. I'm going to get that part ordered now.
完成的
添加一条评论
Did it fix it? I ordered a new cable, it worked for the first time and because of the fans, I took it out and put it back in. It stopped working. Any idea?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jackson Lapes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 85
