跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
646 个问题 查看全部
Why 8GB RAM upgrade failed? (Computer sees only 4GB)
Hi!
So I've decided to put 8GB RAM instead of 2GB available on start in my Macbook Mid-2010 A1342 (White). After reading this page: What is the maximum RAM for a MacBook Unibody A1342?
as one user suggested it should work I put:
2x Kingston 4GB SODIMM KVR1066D3S7/4G, rated 1066MHz into My MacBook. It sees only 4GB after boot. Bank 1 is filled and Bank 0 is empty. I checked each RAM separately in the bottom bank and it works. In upper bank it gives just beeps. No clue what went wrong - I see lots of stuff that people are capable of making A1342 8GB RAM machine.
Please help me!
Regards,
Andy
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Your slot may be dead. I have also seen slots that will take a lessor amount of RAM, so use the 4 in the working slot and try one of the older smaller sticks in the bad slot.
这个答案有帮助吗?
得分 5
3条评论:
+ Good advice mayer. @ Andrzej Sitek1 Did you have both RAM banks filled prior to the upgrade? Have you tried your old RAM in the slot that is not recognizing the 4gb chips? What is the specs on the RAM you replaced? What are the last 3 characters of your serial number?
完成的
@mayer - you might be right. I did some tests: I tried both 4GB RAM in either slot separately. My new RAM is ok because in both cases bank 1 is filled. But When I tried the same ram sticks in Bank 0 it gave beep error and didn't start. I've tried to put old samsung 2x1GB configuration but it detected only 1GB in Bank 1. I tried to put 1GB in Bank 0 and start the Macbook - it beeps, so it seems that one of the slots died:( I'm still on AppleCare so I hope they'll help me.
@ABCelars - I've put ram that's according to Apple specs of 204-pins, 1066Hz, SODIMM, DDR3 so it should work.. As I pointed earlier I tried the old RAM and the slot still doesn't recognize it. Right now I can't check the last three chars of my serial, but what for?
完成的
Try a 2gb RAM. I know with my macbook I could only have a max of 4gb, so maybe that is the same case for you.
完成的
添加一条评论
添加你的答案
Andrzej Sitek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 3,727
