跳转到主内容
Professional tool used most likely for servicing Nokia phones. Device is designed as dongle with internal card-reader.
2 个问题 查看全部
I didn't know the e-composite reference
can you help me? This electronic component, as in the picture, was removed from the xtw100 device, and I did not find it. I want to know its full name, quartz, and its reference, in order to replace it or change it with an alternative. Please help me and thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here's a link that shows the schematic for the programmer.
The crystal oscillator schematic component ref ID is Y2 and it has a frequency of 8MHz as can also be seen on the component in the image you posted. There is no other information as to its other specifications i.e. load capacitance, drive level, ESR etc so it will be difficult to know what the exact replacement would be. (examples only).
It may save a lot of time and hassles if you just purchased a new programmer. (supplier example only) as they are not that expensive.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ahmed Paradoox 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 40
